После обновления, всё сломалось.
Восстановление тоже не работает.
️Версия: 0.2.7 (стабильный)
Приложение: частично запущено (2/4)
Логи ошибок:
identyx-1  | PHP Warning:  Undefined array key "children" in /opt/identyx/api/vendor/composer/../../Models/AppParams.php on line 266
identyx-1  | PHP Warning:  Undefined array key "value_type" in /opt/identyx/api/vendor/composer/../../Models/AppParams.php on line 297
identyx-1  | PHP Warning:  Undefined array key "Автоматическая блокировка сессии при бездействии пользователя" in /opt/identyx/api/vendor/composer/../../Models/AppParams.php on line 274
identyx-1  | PHP Warning:  Undefined array key "maxSessionsCount" in /opt/identyx/api/vendor/composer/../../Models/AppParams.php on line 274
identyx-1  | PHP Warning:  Undefined array key "Прочее" in /opt/identyx/api/vendor/composer/../../Models/AppParams.php on line 274
identyx-1  | PHP Warning:  Undefined array key "Информационная безопасность" in /opt/identyx/api/vendor/composer/../../Models/AppParams.php on line 274
identyx-1  | System has not been booted with systemd as init system (PID 1). Can't operate.
identyx-1  | Failed to connect to bus: Host is down
identyx-1  | 06.10.2025 - 12:52:57: Выполнение скрипта послеустановочной конфигурации с указанием старой версии
infrax-ai-1  | Starting initialization...
infrax-ai-1  | pg_ctl: another server might be running; trying to start server anyway
infrax-ai-1  | waiting for server to start........................................ done
infrax-ai-1  | server started
infrax-ai-1  | localhost:5432 - accepting connections
infrax-ai-1  | Starting supervisor...
infrax-ai-1  | Waiting for PostgreSQL to be ready...
infrax-ai-1  | Database connection successful!
infrax-ai-1  | 2025-10-06 09:53:09 | INFO     | src.main:lifespan:25 - Starting InfraxAI service...
infrax-ai-1  | 2025-10-06 09:53:09 | INFO     | src.database.init_db:init_db:72 - Starting database initialization...
infrax-ai-1  | 2025-10-06 09:53:09 | INFO     | src.database.init_db:init_db:134 - Database initialization completed
infrax-ai-1  | 2025-10-06 09:53:09 | INFO     | src.main:lifespan:29 - Database initialized
video-gateway-1  | guacd[1]: INFO:      Guacamole proxy daemon (guacd) version 1.5.4 started
video-gateway-1  | guacd[1]: DEBUG:     Successfully bound AF_INET socket to host 0.0.0.0, port 8111
video-gateway-1  | guacd[1]: INFO:      Listening on host 0.0.0.0, port 8111
в Установка и развертывание от Октябрьская ЦРБ (150 баллов)
Для детального анализа проблемы просим прислать на почту support@audit-telecom.ru логи контейнеров, которые не запускаются или работают с ошибками.
Как посмотреть и сохранить логи контейнеров
Windows:
По умолчанию приложение устанавливается в папку C:\Program Files\INFRAX\app. Откройте терминал и перейдите туда.
cd "C:\Program Files\INFRAX\app"
Проверьте, что в этой папке находится файл docker-compose.yml.
Linux:
Перейдите в папку, в которую вы клонировали репозиторий.
сd /путь/к/папке/infrax
Проверьте, что в этой папке находится файл docker-compose.yml командой ls
Далее выполните команды:
docker compose logs identyx >logs1.txt
docker compose logs infrax >logs2.txt
В результате появятся файлы logs1.txt и logs2.txt.
Пожалуйста, отправьте эти файлы на указанную почту для дальнейшего анализа.
identyx стал запускаться, infrax - нет
Отправил
Всё заработало
